Third Widget Footer problem
Discussion in 'Gommero WordPress Theme' started by leonkill2000, May 3, 2013.
  1. leonkill2000
    leonkill2000 Member
    Hi
    I have in the following Widget Footer areas.
    First widget (1) WooCommerce New Products
    Second widget -(2) WooCommerce Product Category
    Third Widget a Text widget with (3) Google map iFrame
    All three widgets are showing in their correct columns for all pages except the Products pages.
    On the Products pages (all categories)
    The (3) - Google Maps- is coming into the footer 2 area under (2)
    Webite is http://www.websitesecurityfirst.com/
    Is it possible to fix this ?
    Cheers Leonie
    We have visited your website the problem is occurring due to any one of the plugin you are using,
    Deactivate all plugins one by one and checkout which plugin creating this problem.
  3. leonkill2000
    leonkill2000 Member
    Thank you I will check this out... Many thanks
