Too much padding after removing breadcrumbs
Discussion in 'Dzonia WordPress Theme' started by endgamepr, Dec 15, 2015.
  1. endgamepr
    endgamepr New Member
    Hi there,
    I searched here and found the CSS to remove breadcrumbs from my site. It worked great to remove them, but the space that was originally created for them is still there. This leaves a lot of blank space on pages in between the header and the content. What do you suggest?
    I've uploaded a screenshot to show you what I mean.
    Thanks in advance for your help!
    .content_wrapper {
        margin-top: -40px !important;
    Note: Change numeric value as per your requirement.
  3. endgamepr
    Hi Priyanka,
    Unfortunately that code didn't make any difference. I tried -40, -100, and tried 500, but none of them changed that empty space at all. I checked it with multiple browsers, so it's not a cache issue. Here's a link to the website, which is still under construction: http://eprwebdesign.com/endgamepr/
  4. endgamepr
    Hi Priyanka,
    Okay, so I don't know what I was doing wrong before, but just for kicks I tried it again ... and it worked. Perhaps I mis-copied the code.
    Thank you for the help!
  5. priya
    You're welcome..:)
