top menu not displaying correctly
Discussion in 'VideoCraft WordPress Theme' started by sandradohn, Nov 28, 2016.
  1. sandradohn
    sandradohn Member
    Hi There, I have attached a screenshot of the issue. Thanks, Sandra
  2. sandradohn
    sandradohn Member
    here is the screenshot
  3. Naveen
    Hi Sandra,
    We will soon update our theme in members area and this issue would be resolved in that.
    You will be notified for the updated, till then, you can keep using single lined menu there.
    Your patience and cooperation would be appreciated,
    Warm Regards!
    Naveen Kolhe
  4. sandradohn
    sandradohn Member
    Thanks for the update on this. When do you expect to have this completed? Sandra
  5. Naveen
    Within a week or two :)
