top menu
Discussion in 'BusinessGrow One Page WordPress Theme' started by sandradohn, Aug 21, 2014.
  1. sandradohn
    sandradohn Member
    Hi There, How do I edit the top menu ? I am able to have pages listed in the footer widget abut not up top where they will be easily accessed by users....
    Thanks in advance for your help, Sandra
  2. Yogesh
    Yogesh Guest
    Hello Sandra,
    You can edit menus from header.php file or from dashboard then add your new page link in menus.
    That will resolve your issue.
    Yogesh Bhade
  3. sandradohn
    sandradohn Member
    I was not able to edit in menus . This is the way I have done it in your other themes but it did not work. The pages still do not show on the site.
  4. sandradohn
    sandradohn Member
  5. Yogesh
    Yogesh Guest
    You can edit menu in front-page.php file after line no. 133 as shown below in screenshot.
    Yogesh Bhade
  6. sandradohn
    sandradohn Member
    I have seen your attached file. I do not know what words to put in there....Can you please advise? Here is a screenshot of where I want the menu to show the services pages in a drop down format. http://movingprosdallas.com/ is the website that I am working on....thanks, Sandra
  7. Yogesh
    Yogesh Guest
    We have got your concern, and started working over it. We will reply you soon.
    Yogesh Bhade
