"Top Right Contact Details" field does not respect newlines
Discussion in 'ColorWay WordPress Theme' started by herbertk, Jul 15, 2013.
  1. herbertk
    herbertk New Member
    Please can you convert newlines (like \n, \n\r, \r\n) to <br/>.
    It works when I manually put <br/>, but it is explained nowhere that I can use HTML for this field and what tags I'm allowed to use. So I'm personally okay with HTML, but then you should put an explanation about HTML in the comment to the field.
    The same logic probably goes for other similar fields.
    Anton
