Top right contact, flags?
Discussion in 'BlackBird WordPress Theme' started by annette, Oct 26, 2012.
  1. annette
    annette New Member
    Hallo,
    Can I put flags for different languages, up at the top right corner? Where contact info are right now. If, yes, please tell me how, the easiest way? :)
    Thank you
    You can only put flags in the widget area and theme contain widgets at the footer and at the sidebar (in pages other then home) .
    So it is not possible to add them at the top right corner.
    You can add them at the footer in the front page.
    Thanks.
  3. annette
    annette New Member
    Ok, how do I remove the cellphone and all of the text?
    I want it to be clean at the top right corner. :)
  4. Gourav
    Paste this code in Custom CSS
    .header-info {
  5. annette
    annette New Member
    Thank you!
    What plugin for different languages with flags works best with Black Bird theme?
  6. Gourav
