Top Slider Image Not Centered
Discussion in 'BusinessGrow One Page WordPress Theme' started by b16a3sir, Mar 4, 2016.
  1. b16a3sir
    b16a3sir New Member
    Dixielawnnc.com
    If you view the site in a large resolution like a 30in LED the top image is not centered. I would show you but I see no way to attach a screen shot from my local pc. The file is to large so hopefully you can see this by visiting the site with a large monitor.
    Thank you
  2. b16a3sir
    b16a3sir New Member
    Here is a screen shot in Chrome
  3. b16a3sir
    b16a3sir New Member
    Firefox appears to center, Chrome and Safari do not
    .flexslider {
        margin-left: 249px;
    Adjust the numeric value as per the requirement..
  5. b16a3sir
    b16a3sir New Member
    That option does manipulate it for sure but does not fix my problem. So in almost all resolutions the image in that slider takes up the full screen as we would hope. I assume this is default and is what everyone wants. The only problem is at very high resolutions like a 30in LED the image winds up on the left side of the page. I do not WANT to move it to the left. I do not want to move it at all what I want is for the responsive view to do what we should expect and in this case it should still take up the entire top like the other resolutions.
  6. b16a3sir
    b16a3sir New Member
    Here is what it looks like in almost all resolutions. The first image I posted is what it looks like with a 30in monitor and that resolution btw is 1920x1080
  7. priya
    Try below code for once...
    .flexslider .slides img {
        margin-left: 21%;
    @media only screen and (max-width: 1140px) and (min-width: 960px){
        margin-left: 0%;
  8. b16a3sir
    b16a3sir New Member
    hmmmm I see what you are trying to do and I think you have the right idea but this does not appear to help. Yes it does move the image but it moves it for all resolutions that I have access to. :( Which means the image is now blown up and to the right for the smaller resolutions.
  9. priya
    Could you please send us your dashboard credentials at [email protected] along with this thread link and I will do it for you?
  10. b16a3sir
    b16a3sir New Member
    OK that info is sent
  11. priya
    Thaks for the details...
    We will get back to you soon...
  12. priya
    Hello..
    You would be glad to know that your issue has been resolved...
    Kindly check your site and acknowledge the same...
  13. kristine1g
    kristine1g Member
    It would be nice if you posted the resolution here. I too am having the same problem that I could probably fix myself. Thanks
  14. priya
    Sure...!!! Kristine....
    Use below code in Custom CSS field of your dashboard..
    .flexslider .slides > li {
        width: 100%;
  15. kristine1g
    kristine1g Member
    Thank you Priya!
