Traffica Lightbox
Discussion in 'Traffica WordPress Theme' started by davidgowe, Mar 23, 2016.
  1. davidgowe
    davidgowe New Member
    Prior to using the Paid Traffica version I was using a different lightbox. After the activation of the paid Traffica version I cannot get to use the other lightbox. It now uses the bundled lightbox which I do not want. How can I turn off the light box from Traffica and use the other plugin
  2. nitin
    nitin Guest
    To turn off the light box from this theme, just follow the screenshot given below.
    This will turn off the bundled lightbox feature of the theme. After this, you can use your desired plugin.
    Hope this helps...!
    Nitin
