Hi, I love the theme but would like to change the font/font family, in particular the basic text font on my blog page, it does not seem a suitable reading font. I cannot find any help in the documentation or website. I was thinking of installing USE ANY FONT but prefer not to install another plugin. My website is www.timelyness.co.uk
Hi, Greetings from InkThemes, I would like to let you know that if you want to use any font which is included in the google font library, you can do it with some custom CSS code. In case, you wish to use any other font, you can use any of the plugin mentioned below:- Use Any Font https://wordpress.org/plugins/use-any-font/ Font - official webfonts https://wordpress.org/plugins/font/ Easy Google Fonts https://wordpress.org/plugins/easy-google-fonts/ Hope this helps...! Thanks & Regards! Nitin InkThemes.com
Hi Nitin, Sorry for delay but did not get notification for some reason. I have installed TinyMICE Advanced Editor and it gives my fonts but when they are published the font is not the same as in the editor. If the font in the blog post was same that is all I need see attached. Is there an easy way to do this through CSS or do I need to use these plugins.
Hi, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
Hi, I have replied you in this regard on your email link. Please check your e-mail and let me know. Thanks & Regards! Akbar InkThemes.com
