Traffica PRO - Remove Testimonial & Accordian
Discussion in 'Traffica WordPress Theme' started by davidgowe, Mar 20, 2016.
  1. davidgowe
    davidgowe New Member
    I have the Traffica Pro Theme and for the site that I am building, I do not want to have the Testimonial and Accordian sections on the Home Page. Unlike the Blog, there is no ON/OFF toggle. Do provide directions on how this can be achieved.
  2. nitin
    nitin Guest
    To remove the concerned areas, just paste the code given below in Custom CSS section
    div#demo-wrapper {
    .feature_testimonial {
    Hope this helps...!
    Nitin
    mrodriguezfhe likes this.
  3. davidgowe
    Thank
    That works. But I realize there are 2 more blocks.
    How can I get the front page to display like the free version - nothing else between the. 4 columns features and footer
  4. nitin
    nitin Guest
    Thank you for getting back to us.
    .home-content .home_content {
    Next, just go to (Appearance -> Widgets) of your dashboard. Then from the list of available widgets, just select the 'TEXT' widget and drag-and-drop it to the "Home Page Sidebar Feature Widget Area" on the right.
    Hope this helps...!
    Nitin
