Good morning, I hope you are fine today. I just purchased the Traffica Pro and I have two questions.... On the front/home page the Business logo is asking for an image which i do not want. In place of the logo I want it to say "Open Source Nevada". How may I accomplish that please? Also, I currently have four features showing and I have two more to show....I see the example code that is provided....are there any other example code that I can look at before I try to increase the number of features from four to six please.... Thank you for all you do, Steve
Ok, I got the logo taken care of.... But the Add Feature Box did not work for me...Here is the code I used to attempt to add two more features... [add_feature_box featureimg = 'http://www.opensourcenevada.com/wp-content/uploads/2018/06/harddisc.jpg' featuretitle = 'Data Recovery' featuredesc = 'Hard drives have a finite lifetime and fail without warning.' featurelink = 'http://www.opensourcenevada.com/features/data-recovery/' featureback = 'Malware can corrupt files, disable computers and hold you hostage.'], [add_feature_box featureimg = 'http://www.opensourcenevada.com/wp-content/uploads/2018/06/Partsareparts.jpg' featuretitle = 'E-Recycling' featuredesc = 'We can remove your old equipment and dispose of it properly.' featurelink = 'http://www.opensourcenevada.com/features/e-recycling/' featureback = 'E-Recycling keeps hazardous chemicals out of our environment.' Any assistance is greatly appreciated... Thank you, Steve
Hello, Greetings from InkThemes, I would like to tell you that - You are using the "," in between the string that's why it breaks the shortcode. So, you are requested not to use the comma in the string, You can use a hyphen "-" instead of a comma "," Please use the below-mentioned code to add feature boxes. Code: [add_feature_box featureimg = 'http://www.opensourcenevada.com/wp-content/uploads/2018/06/harddisc.jpg' featuretitle = 'Data Recovery' featuredesc = 'Hard drives have a finite lifetime and fail without warning.' featurelink = 'http://www.opensourcenevada.com/features/data-recovery/' featureback = 'Malware can corrupt files - disable computers and hold you hostage.'], [add_feature_box featureimg = 'http://www.opensourcenevada.com/wp-content/uploads/2018/06/Partsareparts.jpg' featuretitle = 'E-Recycling' featuredesc = 'We can remove your old equipment and dispose of it properly.' featurelink = 'http://www.opensourcenevada.com/features/e-recycling/' featureback = 'E-Recycling keeps hazardous chemicals out of our environment.'] Hope this helps...! Regards, Akbar InkThemes.com
Thank you very much, I really appreciate it...I replaced the comma with a hyphen saved the changes and then refreshed and it still has not worked.... On the features I am trying to get two row of three each...….. Thank you, Steve
Hi Steve, Greetings from InkThemes, I have already replied you in this regard on your email thread. Please check your e-mail and let me know. Thanks & Regards! Akbar InkThemes.com
