Hi. I need to do several things in create ad process. 1) Delete the field “State” because it doesn’t work fine. If you choose Spain as country the field state has not to be mandatory because Spain doesn’t have states 2) In this process (create ad) we can see a lot of labels in English. That labels are not included into po file of the installation I want to know what source programs are where I can modify all this. Thanks in advance.
1) You can disable state field. Go to Settings > Custom field and edit state field from there and disable it from bottom. 2) Please share list of all labels which you want to translate.
Select Category (Top in all pages) -> This is translated in PO file but is in English Ad 23 hours In by Contact Form (on the right) “This field is required” (validations) Send (button) 2 Views Leave comment for this ad Message Map does not change (For example informing 08032 – Barcelona (Spain) ) Create Ad (ad-new) Add New Classified Ads. Button “Next” Button “Upload Image” Button “Go Back” (text is in PO file but is in English) Button “Continue” MAP DOESN’T CHANGE Your listing has bees successfully submited
Download updated version of theme from your members area, We added these text in .po file, You can translate from there. Also send the screenshot of text (Map does not change (For example informing 08032 – Barcelona (Spain) )) where you area getting it.
Ok. I will do that. Excuse me when I wrote "Map does not change". It is not a text. I mean is about Google Map function. Thanks.
I can not see any difference between results of the theme versions. I've installed the new theme version with the new PO file, I've translated again, and results are the same. ¿?
I've compared two versions of the PO files and only differences are: "Payment Transaction" "Your Ad Name:" "Payment Status:" "Payment Amount:" "Payment Currency" "Transaction ID:" "Payer Email:" "Your ad has been successfully submitted" ¿¿??
