Hello, 1.For your 1st issue Go to comments.php present in your theme directory and translate text from there. Check image for reference 2.For your second issue Go to front-page.php present in your theme directory and translate text from there. Check image for reference 3.For your third issue Go to functions > registration_panel > registration.php present in your theme directory and translate text from there. Check image for reference Login and registration buttons are images, if you want to translate it then, go to images directory present in your theme directory and replace your image with present button images or edit it. The name of images are "login.png" "rgs-btn.png" Note:- Use same name for your edited image and remove the current image.
