Translation of the Tap To Call button
Discussion in 'BlackBird WordPress Theme' started by lyubo, Jun 13, 2013.
  1. lyubo
    lyubo Guest
    is there any work around to translate the Tap To Call button in a multisite installation of the Black Bird theme?
    Thank you!
    It is not possible to do so because it is an image not a text, But if you want to change its image then, Go to images directory present in your theme directory and replace your image with present Tap to call image or edit it.
    The name of image is "tap-to-call.png"
  3. lyubo
    lyubo Guest
    Ok, Thank you Gourav!
