translator classicraft template in italian
Discussion in 'ClassiCraft WordPress Theme' started by grignacarbo, Jul 23, 2015.
  1. grignacarbo
    grignacarbo New Member
    hello sorry for the bad English, I have a problem. I need to translate the template in Italian. I took the file from the folder default.po lang template and I translated with the programa poedit. Now in possession of 2 files (.po and .po). These files must be named as? which folder should I put them? I tried to put them in the folder wp-content/languages / themes but I have not solved anything. You help me?
  2. praveen
    praveen Support Staff
  3. grignacarbo
    I followed the instructions but nothing has changed. That's what I did: I changed the po file and after saving I got 2 files (.po and .po), these files will have to be inserted in the wp-content / language that folder wp-content / language / themes also in config.php I inserted the code "define ('WPLANG', 'en_US');" but nothing has changed. The files I have appointed it_IT.po and it_IT.mo. What is wrong?
  4. praveen
    We need your website WordPress access to figure out the issue.
    We will try to fix the issue.
    Praveen
  5. grignacarbo
    hello I wrote by email, you can let me know if everything is ok?
