Transparant layer behind pages and sidebar
Discussion in 'BlackBird WordPress Theme' started by permaword, Aug 3, 2013.
  1. permaword
    permaword Member
    Hi, I want to add a colorfull background image to my website. The result is that the texts on the pages and the sidebar become less visible. Is it possible to put a transparant layer behind the pages and the sidebar?
    Thanks a lot.
    I think you are using old version of theme.
    Please download updated version (1.9.7) of theme from your members area.
    It will fulfill your requirement.
  3. permaword
    permaword Member
    Thanks for your quick answer. However, I am afraid I will loose data by downloading the updated version. Do I have to reinstall all data in theme options for example? Thanks.
  4. Gourav
    If you have make change in .php files then you will loss your changes.Your theme option content and custom css will remain intact.
