Trouble With Accordion Shortcode
Discussion in 'BusinessGrow One Page WordPress Theme' started by mjmersolbarg, Feb 13, 2014.
  1. mjmersolbarg
    mjmersolbarg New Member
    I'm using the plugin Shortcodes Ultimate (http://wordpress.org/plugins/shortcodes-ultimate/) and can't get the accordion shortcode to function properly on my FAQ page. In another theme I'm using, I can click on the spoiler in the accordion and it will open as intended to reveal its contents. In my Business Grow theme, the accordion spoilers remain closed when I click them. Before submitting this topic, I tried an alternative plugin to insert accordions, and it had the same problem.
    Can you help me fix this issue?
    An example can be seen on my site at http://dev.mieggbank.com/f-a-q/
    Thanks in advance!
    Our theme is compatible with almost all the plugin but there are multiple plugins available in WordPress
    therefore it is not possible to check every plugin with the theme, Search alternative of plugin from WordPress.org
    and installed it, This will solve your issue.
