I seem to be having an issue with the Map not showing up on the listings. Check it out at http://bestmarylandrestaurant.com I have gone through the settings and can't find anything related to this not showing. Each of the 3 listings I have created have the map setup when you look at them in the back end. Thanks, BruceMcc
I've just looked and the maps are showing up normally using an Apple Mac with Safari. As an aside you also have problems with html in your listings i.e Gyromania shows html such as </br> line break as plain text!
