trouble with required plugin
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by sandradohn, Oct 28, 2021.
  1. sandradohn
    sandradohn Member
    Hi There, When I try to download the woocommerce plugin, I get an error that says I cannot access the page. Please advise. I have attached screenshots. Thanks, Sandra
  2. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    Try installing the woo-commerce plugin from the add new plugin option.
    If this does not help then kindly send the below-mentioned credential details to [email protected].
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will check the issue and will let you know about it.
    Shemaela
  3. sandradohn
    sandradohn Member
    HI There, It looks like the plugin is installed so I guess it worked somehow. Thanks, Sandra
  4. shemaela21
    Hello Sandra,
    You are most welcome!
    Shemaela
