Trouble with Widgets
Discussion in 'Poloray WordPress Theme' started by mswatko, May 5, 2014.
  1. mswatko
    mswatko New Member
    Im having a lot of trouble with widgets. When I try and add a 2nd widget to the Primary or Secondary area, there will only be a number (1) listed for the sidebar position, there should be a number (2) seeing Im adding a 2nd widget.
    Im using Jetpack and although this worked fine for the squirrel theme, it seems to be an issue for the Poloray theme.
    In my attempt to add widgets I noticed they seem to land in the inactive widget area. If I delete them they also disappear to the assigned sidebar...
    Here is a link to the website Im working on: http://layergrownmodel.com/20/contact/
    Im using the same widgets for all pages, with the exception of the home page.
    Could you please clarify your issue little more.
    Gourav Shrivastava
  3. mswatko
    mswatko New Member
    The issue is, when your adding multiple widgets, there is no way to order them.
    Attached is a pdf file with some screen shots, I hope this helps you understand the issue.
  4. Gourav
    Go to Appearance > Widgets and follow the instruction as shown in image given below
    Now, you can add multiple widgets in both primary and secondary sections, just drag the widget and drop in the order in which you want.
    Gourav Shrivastava
  5. mswatko
    mswatko New Member
    Thank you Gourav, that resolved my issue!
