Trying to re-position homepage featured listing navigation.
Discussion in 'GeoCraft WordPress Theme' started by kentoliver, Jun 3, 2013.
  1. kentoliver
    kentoliver Active Member
    Hey there, I am trying to re-style and re-position the homepage featured listings navigation. I am having problems figuring out how to make a new set of buttons.
    I am trying to remove them from being within the carousel div, so that they are not next to the listings, however above them, in a separate div.
    Right now the buttons seem to be generated by the jcarousel javascript that is in place, I was wondering if you know a quick snippet of javascript so that I can apply it to any custom div class that I am attempting to use.
    Any and all help would be appreciated.
  2. kentoliver
    Bump ^_^
  3. Nitesh
    You can change navigation button from "geocrafttheme/images/slider-btn.png"
    And change there styling through this code.
    .jcarousel-skin-tango .jcarousel-prev-horizontal {
    position: absolute;
    top: 65px;
    left: -5px;
    width: 32px;
    height: 32px;
    cursor: pointer;
    background: url('images/slider-btn.png') no-repeat 0 0;
    width: 22px;
    height: 23px;
    .jcarousel-skin-tango .jcarousel-next-horizontal {
    position: absolute;
    top: 105px;
    right: -33px;
    cursor: pointer;
    background: url('images/slider-btn.png') no-repeat -23px 0;
    width: 22px;
    height: 23px;
  4. kentoliver
    Hey Nitesh,
    Thanks for the advice on styling the current div.
    I was wondering if it was possible to get the navigation to appear outside of the carousel div.
    I can easily style the current div, however I will have to apply some bad styling protocols in order to get it the way I want.
    I would much rather find a solution to re-create the buttons outside of the Carousel div.
    Thanks again!
  5. Gourav
  6. kentoliver
    kk, no problem, I am willing to do that, its just I wanted to check is there was an existing solution that you guys ran into.
    Thanks again for the styling option.
    You can close this thread.
