Is it possible to have two separate blogs on the same site? I want one blog to remain static, and the other is where I will post ongoing blog activity.... Thanks for your help. ~ Robert
Hello, It is not possible to set multiple blog pages with different posts. But yes there is one solution for you. Firstly, Go to the Posts > Categories and create the categories and then Go to the Appearance > Menus > Custom menu and add categories as a menu tabs. Check image for reference. It will add categories at the navigation menu. And then create your blog post and select their respective category. Then your blog post will display individually on their respective category menu page. This will solve your issue.
Ok, this works perfectly. Thank you, Piyush! Is it possible to have the Recent Posts be separated too? In other words, I have Business Posts and Personal Posts. All the Recent Posts for Business will show up on the Business Blog, and all the Recent Posts for Personal will show up on the Personal Blog???
Sorry, another question just came to mind. Can the blog post images that revolve on the home page, be specified for a particular category??? In this case, I would like just the Personal Posts show up... Thanks!
Hello, If you are talking about the recent post carousel slider on the front page then it is not possible to seperate them on the front page.
Understood, regarding carousel slide. Thanks. Is it possible to have the Recent Posts be separated? In other words, I have Business Posts and Personal Posts. All the Recent Posts for Business will show up on the Business Blog, and all the Recent Posts for Personal will show up on the Personal Blog???
Hello, Add Business and Personal categories in the custom menu. It will separate post of both categories. If you click business menu it will open a page with all recent posts of that particular categories and same for the personal category.
