Two categories on top of another.
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by perilo, Nov 6, 2014.
  1. perilo
    perilo Member
  2. Pramod
    Pramod Guest
    Go to Appearance->Editor or theme Editor(it comes from wp editor plugin)
    And delete on line from style.css
    follow below image.
    Pramod
  3. perilo
    perilo Member
    Thx... Not resolved.
  4. perilo
    perilo Member
    The button does not work.
  5. perilo
    perilo Member
    2 categories
      File size:
      27.7 KB
      1
  6. perilo
    perilo Member
  7. Pramod
    Pramod Guest
    Please explain little bit more about your issue.
    If possible provide a screenshot.
    Pramod
  8. perilo
    perilo Member
    Several problems. I uploaded the theme and it did not work. The two categories are appearing at the same time.
      File size:
      25.1 KB
      1
  9. perilo
    perilo Member
    Deleted and installed again, the problem remains.
  10. Pramod
    Pramod Guest
    Please deactivate all plugins if you are using and keep activate only woo commerce.
    Pramod
  11. perilo
    perilo Member
    Not resolved. It is compatible with WordPress 4.0?
  12. Pramod
    Pramod Guest
    Theme is compatible with WordPress 4.0.
    We had tested theme many time and does not find any issue as you are facing.
    Did you install a fresh copy of theme after deleting the previous theme?
    Please do post the list of plugins you are using?
    Pramod
  13. perilo
    perilo Member
    Reinstalled wordpress and the theme. The problem only appears on mobile and internet explorer.
  14. Pramod
    Pramod Guest
    Hello !
    OK,
    Please once check theme after deactivating last four plugin and keep activate only first plugin.
    Thanks & regards
    Pramod
  15. perilo
    perilo Member
    Not resolved.
      File size:
      79.6 KB
      1
  16. perilo
    perilo Member
    Google browser normal site no bugs
  17. perilo
    perilo Member
    The problem appeared when I change the url of the login page theme. Now only works with this url e-login. If I change the error page.
  18. Pramod
    Pramod Guest
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    Pramod
  19. perilo
    perilo Member
    Ok...send.
  20. Yogesh
    Yogesh Guest
    We didn't receive your any mail, have you sent on right email address.( [email protected] )
    Yogesh Bhade
