Two lines in Footer Title
Discussion in 'Infoway WordPress Theme' started by allisonf, Apr 14, 2013.
  1. allisonf
    allisonf New Member
    Hi. I am trying to create a Footer Title in my text widget with the Heading on two lines. How can I specify where the 'enter' for the new line begins.
    Current
    Meet & Greet Port
    Douglas Qld
    Wanted This..
    Meet & Greet
    Port Douglas Qld
    2) I would also like my Feature Page - Heading, to be on TWO lines as well. Making the 'enter' happen at a certain point. How do I do this ? (hopefully the same solution)
    thank you so much! Allison
    Just add "</br>" tag at the place from where you want to break link.
    For example
    Meet & Greet </br> Port Douglas Qld
  3. allisonf
    allisonf New Member
    Hi. thanks for your reply - I thought that 'would' work like a charm. Nice and simple - but
    unfortunately it didn't.
    I added it into the Widget Title
    Clicked SAVE.
    It takes it out automatically. (once you click SAVE - the </br> disappears and the line won't break)
    Anything else I can try ?
    bottom left - 1st widget.
  4. allisonf
    allisonf New Member
    Please see image inserted above. When I click SAVE it wont work.
    rgs, A
  5. Gourav
    Text box does not accept Html tags that's why this issue is occurring to overcome your problem add your title in the text area.
    For example
    <h4>Meet & Greet<br> Port Douglas Qld</h4>
    Sending image for reference
  6. allisonf
    allisonf New Member
    Excellent !!! Thank you so much for your help
