Hi. I'll try to explain my self. My blog: www.blogtodojuegos.cl First: Is there a way of having easy access to all my articles on a section? I mean, for example, I have 5 "featured" articles on every section and 13 "latest" and "popular" ones to the left. BUT I don´t have any option for finding, cronologically, all the articles on that particular section. Only way I figured it out is putting EVERY article as a "featured" for having the list below (1, 2, 3, etc). Is there another way? Second: That leads me to my other problem. If I'm forced to "featured" every article for having the easy access to my blogs in sections, I can't really "feature" real interesting articles on my home page. So... if you don´t have a solution for the above question, is there a way of "featuring" articles for section, I mean, "featuring" on "section opinion", for example, but NOT on the home page? Both options would be great. Thanks.
Well... digging, I found the same request: http://www.inkthemes.com/community/threads/few-problem-with-this-theme.11145/ I did what you said and removed "'meta_key' => 'featured_checkbox'," from "/themes/blogspringtheme/category.php" BUT nothing happened...
I add the content of all my "cathegory.php" file: Code: <?php /** * The template used to display Tag Archive pages * * @package WordPress * */ ?> <?php get_header(); ?> <div class="home_container"> <div class="container_24"> <div class="grid_24"> <div class="page_container"> <h2 class="page_title"><?php printf( CATEGORY_ARCHIVES, '' . single_cat_title( '', false ) . CATEGORY ); ?></h2> <div class="grid_6 alpha"> <div id="tabvanilla" class="inkwidget"> <ul class="tabnav popup"> <li><a href="#" onClick="show_recent(this);" id="leadbutton2" class="leadbutton">Latest</a></li> <li><a href="#" onClick="show_popular(this);" id="leadbutton1" class="leadbutton">Popular</a></li> </ul> <div id="recent" class="register_tab"> <div id="latest_home1" class="latest_home"> <!-- Start the Loop. --> <?php $current_cat = get_query_var( 'cat' ); $args1 = array( 'cat' => $current_cat, ); $query1 = new WP_Query( $args1 ); if ( $query1->have_posts() ) : while ( $query1->have_posts() ) : $query1->the_post(); ?> <!--Start post--> <?php padwriting_main_post(); ?> <?php endwhile; else: ?> <div class="post"> <p> <?php echo SORRY_NO_POST_MATCHED; ?> </p> </div> <?php endif; ?> <div class="clear"></div> <!--End post--> <?php wp_reset_query(); wp_reset_postdata(); ?> </div> </div><!--/recent--> <div id="popular" class="sign_tab"> <div id="latest_home" class="latest_home"> <?php $current_cat = get_query_var( 'cat' ); $args1 = array( 'cat' => $current_cat, 'meta_key' => 'post_views_count', 'orderby' => 'meta_value_num', ); $query1 = new WP_Query( $args1 ); ?> <!-- Start the Loop. --> <?php if ( $query1->have_posts() ) : while ( $query1->have_posts() ) : $query1->the_post(); ?> <!--Start post--> <?php padwriting_main_post(); ?> <?php endwhile; else: ?> <div class="post"> <p> <?php echo SORRY_NO_POST_MATCHED; ?> </p> </div> <?php endif; ?> <div class="clear"></div> <!--End post--> <?php wp_reset_query(); wp_reset_postdata(); ?> </div> </div> </div> </div> <div class="grid_12 center"> <div class="featured_post"> <!-- Start the Loop. --> <?php global $post; $limit = get_option( 'posts_per_page' ); $paged1 = isset( $_GET['page'] ) ? (int) $_GET['page'] : 1; $current_cat = get_query_var( 'cat' ); if ( inkthemes_get_option( 'inkthemes_blog_post' ) != '' ) { $post_limit = stripslashes( inkthemes_get_option( 'inkthemes_blog_post' ) ); } else { $post_limit = 6; } $args = array( 'post_status' => 'publish', 'cat' => $current_cat, 'posts_per_page' => $post_limit, 'paged' => $paged1, 'orderby' => 'date', 'meta_value' => 'on', 'order' => 'DESC' ); $query = new WP_Query( $args ); while ( $query->have_posts() ) : $query->the_post(); featured_post(); endwhile; echo paginate_links( array( 'format' => '?page=%#%', 'current' => $paged1, 'total' => $query->max_num_pages, 'prev_text' => __( '«' ), 'next_text' => __( '»' ), 'type' => 'list', ) ); wp_reset_query(); wp_reset_postdata(); ?> </div> </div> </div> <div class="grid_6 omega"> <div class="sidebar"> <!--Start Sidebar--> <?php get_sidebar(); ?> <!--End Sidebar--> </div> </div> </div> <div class="clear"></div> </div> <div class="clear"></div> </div> <?php get_footer(); ?> As you see, I removed the code 'meta_key' => 'featured_checkbox', but if you go to http://www.blogtodojuegos.cl/?cat=15 you can see the "latest" articles (driveclub, final fantasy and sega) don't show up on the middle.
Hello ! Which theme you are using? I am not getting theme from inkthemes on above provided link. Thanks & Regards Pramod
