For test purposes I have created new wordpress installation with geocraft v2 theme to understand how it works because with losts of listings it was almost impossible to understand how search conditions met. I have created 4 business listing x1, x2, x3 and x4 X1 and x2 is located at frankfurt, Germany X3 located at berlin, Germany X4 located at istanbul, Turkey. All of them are belongs to hotel category and has hotel tag as well When I search "hotel" in search field all shows up which is fine When I search "Frankfurt" in location only x1 and x2 shows up which is fine as well When I search "x" in search field and "frankfurt" in location also correct results shows up but if I search "hotel "in search field and "frankfurt" in location then all 4 listing shows up which I really do not understand. I believe there should be easy fix for that. I did not add hotel in name field as I have already add it in that category and all has hotel tag. If you can explain in details, i will appreciate. By the way example website is xserv.net ( there is no advertisement)
I have replied you in this regard, please check your email: I tried to access your site but, it seems there is some firewall setting you have applied on your server and I was unable to check your site. Kindly, allow our IP so that, we can check your site and provide you appropriate solution. Warm Regards! Naveen Kolhe InkThemes.com
Hello Naveen, Thank you, I have received your email, there is no firewall settings as it is hosted on shared hosting at bluehost. Maybe there was downtime, can you check again if you can reach now
Hi, Hope you are doing good...! Actually, you got confused between listings and posts. Let me clarify them. These are two different segments in the GeoCraft Theme. You are allowed to enter the listings from Dashboard-> Business Listings while the Posts are added from Dashboard->Posts The search function on the homepage works only for the listings. You have added the data as posts namely x1, x2, x3, x4.... You need to add these from Business Listings section under Dashboard-> Business Listings-> Add New Listing. Things will start working for you. For more information, you can refer to the documentation of the theme. Hope this helps...! Thanks & Regards! Nitin InkThemes.com
