Uninstalled post scroller on front page, but posts keep scrolling
Discussion in 'Infoway WordPress Theme' started by keikland, Nov 20, 2013.
  1. keikland
    keikland New Member
    Installed SmoothSlider and thought the effect produced a pretty messy front page, so I uninstalled it. However, posts keep scrolling, even new ones, in a space between the feature settings and the footer elements. The scrolling posts are at www.energyper.com.
    There are no traces of the plugin left, and I manually dropped the smoothslider tables in the database - but no results. I have also checked the widgets of the theme, and there is nothing there.
    Being well versed in IT but a newbee in WordPress, I have absolutely no clue what to do now. If anyone has suggestions, it would be immensely appreciated.
    I think you are talking about home page post carousel slider.
    For this go to the
    Theme directory > js > jcarousellite_1.0.1.min.js
    and set "scroll" value to '0'
    Check image for reference.
  3. keikland
    keikland New Member
    Hello Gourav,
    Thank you very much for your reply. You are correct, and I changed the parameter as you suggested. This stopped the scrolling, which is a major improvement in itself. However, I really wished to remove the feature altogether. Could I for example just delete the two jcarousellite_1.0.1.min.js and jcarousellite_1.0.1.pack.js files, or is this too simplistic?
    Kjell
  4. Nitesh
    Hello Kjell,
    Removing js files will break carousel slider. So it is not a good solution.
    If you want to remove slider completely from front page then Paste this code in Custom CSS
    #carousel-full {
    display:none;
    Nitesh Raghuwanshi
