Unlimited Slider Shortcut Problem
Discussion in 'ColorWay WordPress Theme' started by beautyplaza, Sep 18, 2015.
  1. beautyplaza
    beautyplaza New Member
    I have a problem adding shortcuts for more sliders. This will effect the slider pictures like shown on the pic. It looks as the layer is doubled. Any idea how I can solve the problem?
    There are 12 slider options are already available in the latest ColorWay them but still if you are interested in adding more slider images over there then for this there would be requirement of some customization in the source code.
    So please send us your dashboard credentials at [email protected] and we will resolve your issue.
    Note: In the latest theme shortcode will not be applicable for the extra slider on the homepage.
  3. beautyplaza
    Hello Priyanka,
    thank you for your reply. I only have 6 sliders and "Add unlimited sliders". In Colorway Pro is no update available, only in Colorway. I will send you our credentials ;)
    Best regards,
    Petra
    Hello Petra,
    Thanks for the details...
    We will get back to you ASAP with a positive response.
