Unlimited Testimonials Shortcode
Discussion in 'ColorWay WordPress Theme' started by brownbebe, May 22, 2015.
  1. brownbebe
    brownbebe New Member
    Hello Support,
    Would you please post the Shortcode for Unlimited Testimonials on the Home page? Our copy of the readme.txt file does not include it. Step 6 is cut off after the title.
    This is a very good theme. Thank you for your help.
  2. brownbebe
    Also, can you tell us how to slow the speed of the testimonial slider?
    Thank you.
  3. praveen
    praveen Support Staff
    Hello!
    1>To use unlimited Testimonial in home page, we will suggest you to use some Testimonial plugin.
    You can also use Easy Testimonial plugin which will provide you shortcode to use in the theme.
    2>To change slider speed, please follow the screenshot given below.
    Praveen
  4. kellycbfmkg
    kellycbfmkg New Member
    I was searching for an answer to the same question - how to slow down the testimonial slider speed. The screenshot you included above a the solution is the adjustment for the main slider only, not the testimonial slider. Is there a way to specifically adjust the testimonial slider speed? The default speed is much too fast to be read by site visitors.
    Thank you!
  5. praveen
    I have got your concern,
    Praveen
  6. kellycbfmkg
    Thank you again! Perfect!
