updated sidebar question
Discussion in 'BlogsTrend WordPress Theme' started by faceless4all, Feb 6, 2015.
  1. faceless4all
    faceless4all Member
    http://www.inkthemes.com/community/threads/sidebar-question.15800/
    Hi Pramod, I did try to add the codes to change index.php from the second image you provided, but when I check the site after, it shows unexpected error for the ending line (?) which I think was this:
    <!--End Sidebar Wrapper-->
    </div>
    <?php get_footer(); ?>
    Would it be possible for you to copy and paste codes here for this php file, and/or entire file?
    Thanks.
    Jo.
  2. Pramod
    Pramod Guest
  3. faceless4all
    faceless4all Member
    Hi Pramod,
    All is good!
    Thank you.
    Jo.
