Upgrade to Pro meant I lost Home Page format
Discussion in 'ColorWay WordPress Theme' started by mikegale1, Jun 2, 2015.
  1. mikegale1
    mikegale1 New Member
    Hi, I upgraded my Colorway theme to Pro yesterday. I have since lost the Home Page that I wanted and created using the Lite version.
    The website is china-connexions.com
    The Main Menu now is also experiencing issues. The Home option appears twice, so does Blog (all of which are pages that I do not want to appear on the Home page). Finally, the language option in the Menu is unresponsive and does not show the drop down column with the different language options.
  2. Sobhagya
    Sobhagya Guest
    It seems that you missed to turn on the front page,
    Kindly follow the below step mentioned in the image,
    Hope it will solve your issue.
  3. mikegale1
    Unfortunately, the problem isn't so simple. The Front Page is switched ON. I even tried turning it Off& On again.
    I'm not sure what the issue is otherwise.
  4. Sobhagya
    Sobhagya Guest
    Hello Mikegale,
    We have got your concern, please send us your WordPress dashboard admin login details at [email protected]. so that, we can have a look over the issues in detail and will try to resolve them ASAP.
    Your website Login link:
    WordPress username:
    WordPress password:
    Note: Once your issue get resolved, you can change your password.
  5. Sobhagya
    Sobhagya Guest
    Hello Mikegale,
    We have resolved your issue
    Please have a look at your website.
    Hope you are enjoying InkTheme services.
    Do let me know if you need any help.
