Upgrade to Themia Pro has destroyed formatting
Discussion in 'Themia WordPress Theme' started by stevehale, May 31, 2015.
  1. stevehale
    stevehale New Member
    I upgraded from Themia-Lite, so I could get responsive format for mobiles for our family blog.
    Now the formatting has all gone!
    All the text I have written no longer has carriage returns and all line spacing has gone. I have to double enter a carriage return to get a line space so this makes the formatting in the back end look very silly.
    Also if I enter </p> at line ends in text mode this gets ignored and removed.
    What has happened and why and how can it be fixed please!
    Steve B
  2. praveen
    praveen Support Staff
    Could you please provide us URL of your website along with some edited screenshot of your issue so that we can assist you accordingly?
    In case you are unable to create a screenshot, you can follow the link http://www.screenpresso.com/ which will help you to create screenshot easily.
    Praveen
  3. stevehale
    The web site is:-
    www.braggfamily.co.uk.
    If you go to this link I have had to do DOUBLE carraige returns to get the formatting.:-
    http://braggfamily.co.uk/lornas-90th-birthday-tea/
    See how I have had to force two line spaces to get the formatting!
    On this link the text has been typed in as normal and even though there are carriage returns in the editor they do not appear on the site properly:-
    http://braggfamily.co.uk/a-boating-we-shall-go/
    Notice how the line spaces are there but that the formatting does not appear on the site.
    I have had to split this into two posts.....
    Before I upgraded to the Pro version of Themia it was all OK.
    However I cannot get the screen dumps to come into this article. I keep getting an error message saying the article is too long!
    Please can you advise
    Regards
    Steve B
  4. stevehale
    Any reply to this please as it is getting to be VERY frustrating!
    Regards
    Steve B
  5. praveen
    Hello, Steve B!
    I am sorry for the inconvenience caused.
    We need your dashboard access to figure out the issue.
    Kindly send us your website WordPress login details at [email protected] along with the thread link.
    We will check out the issue at our end and try to fix it.
    You patience will be appreciated.
    Praveen
