Upgrading help needed from Lite to Pro
Discussion in 'Cloriato WordPress Theme' started by opendoortestprep, Apr 23, 2014.
  1. opendoortestprep
    opendoortestprep Guest
    I already loaded the pro version onto the dashboard and so know both Lite and Pro are on there, how do I switch them over and will the website be down while this happens? Is there no easy way to just activate the Pro and it all switches over then?
    Thanks!
