upload button for media is not working...
Discussion in 'Blackriders WordPress Theme' started by sandradohn, Mar 13, 2017.
  1. sandradohn
    sandradohn Member
    Hi There, When I try to upload a pic in the media part of the theme , it does not work. The button does nothing when I click it. Please advise. Thanks, Sandra
  2. Naveen
    For your information, it may happen that some of your plugins are conflicting in your site,
    You are requested to deactivate all of your plugins once and check your site's again,
    Then activate one by one your plugins checking result on each activation,
    Hope this will let you figure out the messing up plugin.
    Warm Regards!
    Naveen Kolhe
  3. sandradohn
    sandradohn Member
    Ok, will try. Thanks, Sandra
  4. Naveen
    Sure!
  5. sandradohn
    sandradohn Member
    That worked. Thanks, Sandra
