upper right corner of the theme
Discussion in 'Cloriato WordPress Theme' started by details, Jan 22, 2014.
  1. details
    details New Member
    I want to create a coupon on the upper right left corner of the theme. I would like visitors at the website to be able to click on the coupon and to print it out as .pdf-file.
    Thank you.
    Benji
    It is not possible to add a downloadable file in the header area, You can add a downloadable file in footer widget area, If you want to do, so then go to Appearance > Widget and drag "Text Widget" and add downloadable file there and drop it in the third widget area.
    For creating a downloadable file, Please follow the link given below
    http://www.wikihow.com/Make-a-File-Downloadable-from-Your-Website
    I hope it will help you.
    Gourav Shrivastava
