Urgent Help Google Maps in ClassiCraft
Discussion in 'ClassiCraft WordPress Theme' started by taylor50plus, Aug 22, 2018.
  1. taylor50plus
    taylor50plus Member
    Hi Guys
    I need to sort the maps out in classicraft, it was working before, but now i need to install API key, think google has done some update
    When i go to settings as looking on the forum here, i do not see google map API like the screen shot
    can someone help fix this issue
    https://oxfordlocals.com
    Can someone log in and fix for me
  2. taylor50plus
    taylor50plus Member
    I have tried uploading the new update theme, but it deletes my child theme, i delete old theme, then upload new theme, my child theme disappears, can you please help
  3. Naveen
    It seems you are using an older version of the theme, please make sure your parent theme version should be Version: 2.0.4.
    You can download the updated theme from your members area and use it on your site.
    If you are already using the updated version still getting such issue, please share your WordPress admin login details at [email protected] along with this thread link.
    We will check your site and do the needful.
    Regards!
    Naveen Kolhe
  4. taylor50plus
    taylor50plus Member
    I tried uploading, new theme, delete old first, this is ok, however, my child theme disappears, and my customisation have gone, thats the problem
  5. taylor50plus
    taylor50plus Member
    So installing is ok, its my child theme which disappears after the new theme is installed
  6. akbar92
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful.
    Akbar
  7. taylor50plus
    taylor50plus Member
    Guys, this is still not sorted, I now have 2 themes the same different versions, if I delete, old one and keep update, my child theme disappears.
    Can you help sort it
  8. akbar92
    I asked you to give us an editing permission, Please give us an administrator role so that we could do the needful word for you.
    Akbar
  9. taylor50plus
    taylor50plus Member
    Akbar,
    Thank you very much for sorting this out, on the next update, you may have to install.
    Thanks for the support
    Regards
    Robert
  10. akbar92
