Urgent Help Please 2 menus showing up on ColorWay
Discussion in 'ColorWay WordPress Theme' started by Sammy, May 30, 2013.
  1. Sammy
    Sammy New Member
    Kiderminster Worcestershire
    Hi I have uploaded the new 3.2 version of ColorWay to replace the old version of the theme at www.skbtaxis.co.uk - now there are two menus showing up - I have recreated a new menu in the menus section with the drop downs the same as before but whatever I do there are 2 menus instead of 1 help please.
    Sam
    We have checked your website and there is no problem with the menus. If you still having the problem then send us the screenshot and also specify in which browser you have getting this issue.
  3. Sammy
    Sammy New Member
    Hi There Gourav, I have just checked and there is no problem in firefox or IE but I only use Chrome and there are definitely 2 menus showing - screen shot attached - if I click on where it says pages navigation menu it hides the top line of duplicate menu - clicking on those words again makes the top line duplicate menu reappear
    Many Thanks
    Sam
  4. Gourav
    We have checked you website in all browsers But not found such issue
    Please check the screenshot of Chrome
    It is the problem of cache, So clear your cache and check your website again and also check it on another PC, It will work fine.
  5. Sammy
    Sammy New Member
    You were dead right it was a problem with the cache - sorted straight away many thanks as always - have a great weekend
