Using a shortcode in "Feature page Heading" on home page
Discussion in 'Infoway WordPress Theme' started by lkodsmann, Feb 4, 2016.
  1. lkodsmann
    lkodsmann Guest
    Hello! I'm using Event Espresso to handle my events/ticketing/etc, and I'd like to be able to use a shortcode in the "Feature page Heading" section of the homepage.
    When I place the shortcode here, it just displays the shortcode text... On a page, the shortcode works perfectly - so I'm assuming that there's just a chunk of code I need to edit/add to make this work in this section?
    Thank you so much for your help!
    Would you please provide us link of the plugin so that I can check this at our end and provide you the solution accordingly..
  3. lkodsmann
    lkodsmann Guest
    Here is the link to the plugin: https://eventespresso.com/
    I just need the "Feature page Heading" section to be able to correctly interpret a shortcode...
    The shortcodes for this plugin work fine on the subpages (in the main content area), so I think there is just something about how the "Feature page Heading" is coded that it won't interpret the shortcode, and instead just displays the shortcode text instead.
    Thanks for your help!
  5. lkodsmann
    lkodsmann Guest
    Hm... that puts it in the entirely wrong place (in the first of the three feature boxes, not in the "Feature page heading" area). I tried putting your code in the "infotag" area of the front-page.php file, but that didn't seem to work well (it didn't align properly, placing the horizontal line next to my content instead of below). Please advise! Thanks for your help!
  6. priya
  7. lkodsmann
    lkodsmann Guest
  8. nitin
    nitin Guest
    Hope you are doing good...!
    You are requested to kindly use the php code snippet <?php echo do_shortcode('[ESPRESSO_EVENTS title="test"]')?> as suggested in the above screenshots.
    Incase, you still remain with the issue, just send us your website WordPress login details at [email protected] along with the thread link.
    Your Website URL:
    WordPress Username:
    Password :
    We will do it for you.
    Nitin
