Using columns in Homepage Content Area
Discussion in 'Elite Pro WordPress Theme' started by cornucopiax, Jan 30, 2016.
  1. cornucopiax
    cornucopiax New Member
    Is it possible to use columns in the 'Homepage Content Area' in the (Appearance --> Theme Options) section?
    I would like to divide my text into two columns, side by side, same width, taking up the full width of the whitepsace. I have tried using [col] and so on, but this hasn't worked.
    Thanks again,
    Would you please explain your issue with some edited screenshot of the concerned area along with your site URL so that we can assist you accordingly..?
