Using lead capture widget other than on home page.
Discussion in 'Infoway WordPress Theme' started by dnolte, Feb 17, 2016.
  1. dnolte
    dnolte New Member
    I have the lead capture widget on the home page and it works fine, but I would like to also have it in the sidebars of other pages, and it looks cut off. How can I either make the lead capture widget more responsive to its container or make the non-homepage sidebar the same size as the homepage one?
    Site: http://denisehockley.com/test
    .sidebar {
        padding-left: 0;
        padding-bottom: 25px;
    @media only screen and (max-width: 960px) and (min-width: 767px){
    .sidebar {
        width: 100%;
        padding-left: 6px;
  3. dnolte
    dnolte New Member
    I pasted the code shown as described. It changed some things but made others worse The problems are most apparent on computer screens
    1. The form partially obstructs the main column on computer screens
    2. The padding on the right side of the form is much larger than on the left
    3. The Recaptcha image and Send buttons spill outside the form boundaries to the right (this may be the cause of 1 and 2).
    See http://denisehockley.com/test/locaton
  4. dnolte
    dnolte New Member
  5. priya
    Would you please try below code and check after that...
    .inkleadsform .signinForm ul.inkleadsul li.inkleadsbutton input[type="submit"] {
        margin-left: 0;
    .sidebar {
        padding-left: 45px;
    .sidebar {
        padding-left: 0;
        width: 100%;
    .sidebar {
        width: 100%;
        padding-left: 13px;
    Note: Adjust the numeric value as per the requirement..
  6. dnolte
    dnolte New Member
    Better but still not quite. The ReCaptcha and the send button still are misplaced on computer screens.
  7. priya
    Please paste the code given below in Custom CSS section of your dashboard.
    img#recaptcha_challenge_image {
        width: 90%;
        width: 100%;
        margin-left: 0;
  8. dnolte
    dnolte New Member
    Almost perfect except for one thing: hovering the mouse over the button causes the button to jump out of the frame.
  9. priya
    Use below code..
    .inkleadsform .signinForm ul.inkleadsul li.inkleadsbutton input[type="submit"]:hover {
        width: 100%;
