Using Pro on multiple domains
Discussion in 'ButterBelly WordPress Theme' started by mckinlt, Mar 31, 2017.
  1. mckinlt
    mckinlt Member
    I bought pro for novamidwife.org. I'd now like to use it also with hrmidwife.com. How do I do that? Thank you.
  2. Naveen
    Just download the zip file from member's area and install it on your other site.
    Then you can configure it as you did in your previous site.
    Warm Regards!
    Naveen Kolhe
