Using System with WP-Client Portal
Discussion in 'InkThemes-Support Working Hours' started by netlover, Sep 19, 2018.
  1. netlover
    netlover New Member
    I'm doing implementation of Credit Repair Theme on a site that has woocommerce and wp-client portal installed which you can learn about here:
    https://wp-client.com/
    I have some questions:
    Does your membership plugin integrate with Woocommerce?
    Does it support the NMI payment gateway?
    https://www.nmi.com/
    Does it support multi tiered memberships? you can see the client's products/memberships here:
    https://aficreditsolutions.com/shop/
    Does the membership plugin support authorize.net cim and sim? If so, does it let you change the post URL?
