Hi everyone, Could anyone that is using Wordpress SEO plugin with the theme advise if they are experiencing any problems with edits and cache holding until the plugin is deactivated and reactivated again, or having any page loading problems unless procedure is repeated. I notice that edits do not show when logged out unless completing procedure. Appreciate any views. Cheers Tob
Yoast plugin? I really want to use this as it is 'allegedly' the best SEO plugin. But my knowledge of the plugin is limited and I'm not sure what options to tick. We need a dedicated 'How to' thread for SEO for this theme with particular emphasis on the Yoast service IMHO.
I've been using Yoast for the past 2 months and it has been working great. I had to change the title tags to prevent the duplicate site name from appearing. To source or at least get closer to finding your problem the only thing I can recommend here is to deactivate all of your other plugins then test again and see if the problem is caused by a plugin conflict or the code. If it works then activate each plugin one at a time to see which one is breaking it.
Thank you Rodger for help, I will complete one by one and hopefully will show up the conflict. Many thanks! Tob
Thanks Roger, Maybe getting some where, I have been able to narrow it down to 2 plugins and each on their own will cause the problem, WP Super Cache and Wordpress Firewall 2 . I have deleted both and replaced with new uploads ans still getting the problem. I have the WP Super Cache setup in advanced mode, So looks like one or both are conflicting. Tob
I'm using Hyper Cache and OSE Firewall without any conflict. BTW: I'm getting around 12 Apache emails a day notifying of attempts to hack with almost all of them coming from ChinaNet. Wow.
Thank you for that, I wil give them a try and see , China calling I mainly get the Russian Federation, "Siberian Networks Ltd.", guess this is the world wide web working. Take care and many thanks again Rodger.
Hello Rodger, thank you again for your info on the plugins, I have installed and so far it looks like correcting my problems, actually the site is running faster, again many thanks. Tob
I am using Ultimate SEO. Information on dashboard as well as under each business. This makes it easy to edit each business from a long list or or its page. The list allows you to click to an individual business listing. Seems totally compatible with GeoCraft and offers more features than recommended SEO All in One. Another reason I like Ultimate SEO. I imported a cvs list and business with an associated photo media did not show-up in business listing. When I switched over to Ultimate SEO, I went to its business listing secison and saw all the non-shows. Each listing has a number so you know which one to delete if you have already reentered the data. If you have not reentered the listing, all you need to do is click on edit and you are switched over to the dashboard business listings area. Remove the media from the business listing description area and saved. Eliminating the non-shows made my site work faster.
Hi and thank you, appreciate your sharing info, WP Super Cache seems to be more unstable since the last plugin update and has been reported to not correctly clear the cache. I agree with Rodgers recommend on different server which looks excellent value and service. I think this theme has to be run as light as possible with only the min amount of plugins, so your idea of having classified's or any other theme addition on a sub domain or even another domain a good idea but should be opening in another tab or page so as not to leave the site. There is still the issue of the images which are added with the directory listings, these need to be optimized and most of all be available to add title and alt tags. This is something which also shows up on SEO reports as needing to be corrected. Cheers Tob
