Hi, I downloaded and activated WP Editor as my Roadfighter doesn't display a theme editor. However, it is not showing me the Editor option in the menu. Has the settings tabs for the plugin but not the editor. How can I fix this please? Thanks, John
Hello, John... Greetings from InkThemes! You will get Theme Editor option Under Appearance option of your dashboard.. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hi Priya, The theme editor does not appear under Appearance. I have Themes, Customize, Widgets, Menu, TAC, Theme Options. Thanks, John
The reason for my query is that a client is having trouble with the contact page. A couple of clients have suggested that they filled in the form and the admin did not get the details. I am interested in change the contact email address to one of mine to test it or alternatively a quick question please; Can I add a contact form plugin to override the built in contact page. Thanks, john
Hello, John.. You can easily replace the email id with your desired one and for that, you just need to follow the screenshot given below. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Priyanka, I will look for the file to edit with Filezilla because as I have stated EDITOR is not showing up as an option under Appearance. Thanks, John
Ok..!! John.. By the way, you can use "wp-editor" or "wpide" plugin as well for the editing purpose.. Thanks & Regards! Priyanka InkThemes.com
