V2 install help
Discussion in 'VideoCraft WordPress Theme' started by ahoque, Nov 13, 2014.
  1. ahoque
    ahoque Guest
    I made heavy modification on my vcraft theme v1; I simply want to update the essentials. Which files should I focus on to make the manual change?
  2. Yogesh
    Yogesh Guest
    We mainly change the style of theme that is we make it to look more attractive.
    Please see changelog.txt file in v2 theme folder,what we did in our latest version.
    In which files you did customization ?
    Yogesh Bhade
  3. ahoque
    ahoque Guest
    Hello, I made changes to many files that I cannot name. If I just want to make changes to the look, what file would you recommend I update?
  4. Yogesh
    Yogesh Guest
    Keep old style.css file then update style.css file mainly.
    Yogesh Bhade
  5. ahoque
    ahoque Guest
    Sorry, a little confused. Am I to overwrite the old style.css and replace with the new style.css?
  6. Yogesh
    Yogesh Guest
    I mean to say, keep your old style.css file anywhere like as backup then use new style.css file in theme.
    If any issue will generate then you can use your old style.css file.
    Yogesh Bhade
