Variant Theme New Help with Two Column Form
Discussion in 'InkThemes-Support Working Hours' started by xy7tina, Dec 12, 2016.
  1. xy7tina
    xy7tina New Member
    When I ask you in theme sub forum you send auto reply the same as the one before - please look at the problems with the auto form at www.ssdihelpcenter.com tell me how to may 2 column form so it stays in header area and does not misaglign the rest of the content
    Tina Dixon
  2. Naveen
    Hello Tina,
    You are not supposed to display the form in two column, However, yYou can display the it with scrolling feature, for that, you need to paste the below custom CSS code in Dahshboard->Appearance->Theme Options->Styling settings->Custom CSS field.
    .form_wrapper_custom {
        height: 500px!important;
        overflow: scroll!important;
    This will help you to figure it out and resolve the issue(s).
    Warm Regards!
    Naveen Kolhe
  3. xy7tina
    xy7tina New Member
    Good Morning,
    I thank you for your help but the scrolling bar is not working and I need two more items to the form
  4. Naveen
    It seems you want to add more fields to the form, kindly check your FormGet form and add new fields to that.
    Also, if the above code is not working then, allow us to apply the changes to your site.
    Just share your WordPress admin credentials at [email protected] along with this thread URL:
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    I will check and do the needful.
    Warm Regards!
    Naveen Kolhe
