1. Is there some way to add a description to the mobile menu? Right now there is a black bar with the 'hamburger' icon on the right. Not enough information to users. Is there some way to add text, for example 'Page Navigation' to the black bar? 2. The lead capture widget seems to have space to contain a header to the widget, for example 'Contact Us' but no apparent way to define it. found found answer 3. The lead capture widget seems to be stuck on blue rather than following the color scheme of the theme. It should either follow the color scheme of the theme or have a color setting of its own. found answer 4. Is there a way to get rid of that massive quote mark in the quotations section? BTW I am also having the recaptcha Input Error problem noted in another thread. found answer Website under development denisehocklye.com/test using infoway 1.7
Hello, Greetings from InkThemes! 1) Is there some way to add a description to the mobile menu? Sorry, this would not be possible but for you, we can add your desired text below of that area.. 2) Is there a way to get rid of that massive quote mark in the quotations section? Please provide us some edited screenshot so that we can assist you accordingly.. If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hi, Greetings from InkThemes, To get rid of that massive quote mark in the quotations section, just paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .testimonial p { background: none; } Hope this helps...! Thanks & Regards! Nitin InkThemes.com
