I am having difficulty with the following: 1. Getting the static page settings configured so that the homepage displays like the demo (slider, feature areas). 2. I would like to remove the "Business Logo" text. 3. I would like to remove that contact box on the homepage. Our website is: fsch.larrygreen.org
Hi, Greetings from InkThemes! Solutions to your above issues are accordingly... 1) Getting the static page settings configured so that the homepage displays like the demo (slider, feature areas). Please follow the screenshots given below. 2) I would like to remove the "Business Logo" text. Please follow the screenshot given below. 3) I would like to remove that contact box on the homepage. Please paste the code given below in Custom CSS filed (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .caption { display: none; } Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Thank you for your response. Just a few follow-ups: 1. The Custom CSS did not remove the box. 2. My theme options does not have "Front page on/off" 3. when removing the "business logo text", I don't want my logo there. Is there a way to eliminate that entire area so the logo and the call button aren't displayed?
Hi, 1) The Custom CSS did not remove the box. I have checked this code and it worked perfectly as it should be.. So you are kindly requested to clear your cache and check the result after that.. 2) My theme options does not have "Front page on/off" Have you checked General settings option under Theme Option..? If yes and still get the same issue, you are kindly requested to reinstall the theme.. 3) when removing the "business logo text", I don't want my logo there. Is there a way to eliminate that entire area so the logo and the call button aren't displayed? For this, please paste the code given below in Custom CSS field of your dashboard. Code: .header_container { display: none; } Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Thanks for all your help. The only remaining issue is that the front page setting still does not appear even after reinstalling.
Hi, It seems that you have not configured your settings appropriately... Kindly follow the screenshot given below. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hello, To determine and fix the issue, we need to access your dashboard. So, send us your website WordPress login details at [email protected] along with the thread link. Your Website URL: WordPress Username: Password : Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
