Greetings: I am using Elite Pro and my drop downs are too long to be viewed (they go down below "the fold"). My site has a lot of information and I need the drop downs to go only so far and then maybe form another column to the right. (I know I could create subheadings but I would like for people to see all that is there under the parent.) Could you please tell me how to do this, or else suggest another theme I could migrate to that might be more suitable for sites with a lot of content? Thank you, Emily
Pramod, As my site is under development, it is not yet published so I cannot send you the link (I'd have to send you credentials too). Do you have any ideas? Does ink themes have any themes with wide menus which form the drop down list into columns?? I can send you a screen shot if you like, tried to attach it to this email but it kept saying that my message was too long. Thank you, Emily
Is there a plugin I can use to make it a mega menu, like this? http://wpmegamenu.com/megamenu/ Would this work with Elite Pro? What does Ink Themes recommend?
Hello, You have to use following plugin for it. https://wordpress.org/plugins/megamenu/ It will resolve your issue. Thanks & Regards Yogesh Bhade
