VideoCraft Integration with CCAvenue Payment Gateway
Discussion in 'VideoCraft WordPress Theme' started by adnanhmd6, May 8, 2015.
  1. adnanhmd6
    adnanhmd6 Member
    Bangalore
    I would like to integrate CCAvenue with VideoCraft theme. Could you provide me the procedure or recommended plugin that can provide the best solution without compromising on performance and security.
  2. praveen
    praveen Support Staff
    It is possible to integrate CCAvenue with the VideoCraft Theme but it will require a lot of customization in the source code of the theme.
    So, you are suggested to hire a freelancer for this.
    I would like to recommend you WooCommerce CCAvenue gateway
    Hope you find above information helpful.
    Praveen
  3. adnanhmd6
    adnanhmd6 Member
    Bangalore
    Thanks for the response, i have integrated the payment gateway button without any customizations.
